» MEAP » MEAP Application Settings » Installing MEAP Applications » Attention (Installing MEAP Applications)
Installing Applications
There may be other specific requirements for installation, depending on the application. For more information, see the instruction manual provided with the application.
You can install up to eight applications.
You cannot install license files only. Specify both the application file and the license file.
To only add a license file for an application that is already installed, see"Adding License Files."
Obtaining License Files
In order to install an application, a valid license file is required.
If you have a license access number in your application package, obtain a valid license file from License Management System (http://www.canon.com/lms/license/).
In order to obtain a license file, a license access number and a device serial number (the number displayed on the upper left of the SMS screen) are required.
If you do not have a license access number in your application package, it will be provided by the dealer where you purchased the application. For more information, see the instruction manual provided with the application.
Storage Area
The application can use a maximum storage area of 32MB. You can confirm the storage space used by the application "Storage", under resource information displayed on the [MEAP Application Management] page.
When you are updating an application
Stop the application before installing the new version.
051R-0F7
