» Appendix » The Lists Common to Certain Settings in the Print Mode
The following lists are samples. The contents may partially differ from the lists printed by your printer.
PCL Font List
A list of the fonts that can be used in the PCL mode is printed.
Make sure that the printer is online.
Press [  ] (Utility) to display the [Utility Menu] menu.
Select [PCL Utility] using [ ] and [  ], and then press [OK].
4.
Select [Font List] using [  ] and [ ], and then press [OK].
5.
Select [Yes] using [  ] in the [Execute?] display, and then press [OK] to output the page.
PS Configuration Page
The settings of the [PS] options are printed.
Select [PS Utility] using [  ] and [ ], and then press [OK].
4.
Select [Configuration Page] using [  ] and [ ], and then press [OK].
5.
PS Font List
A list of the fonts that can be used in the PS mode is printed.
4.
5.
051R-0LK
