» Troubleshooting » Poor Printout Results » The Printing Position Is Skewed
Perform one of the following solutions according to the cause.
<Cause 1> [Gutter] is specified.
Solution
Perform the following procedure in the printer driver.
Display the [Finishing] sheet.
Click [Gutter].
Set [Gutter] to "0."
You can specify the same setting from the printer's control panel.
<Cause 2> [Offset Y] and [Offset X] are specified.
Solution
Set [Offset Y] and [Offset X] to "0."
<Cause 3> "Top Margin" and "Paper Position" in the application are not specified properly.
Solution
Specify the settings for "Top Margin" and "Paper Position" in the application properly.
See the instruction manual supplied with the application.
<Cause 4> The printing position is adjusted in [Adj. Start Position].
Solution
Adjust the printing position to an appropriate value in [Adj. Start Position].
051R-0KL
