For details on the installation site, see "Confirming the Supplied Accessories and Checking the Installation Site."
Before moving the printer, see "Important Safety Instructions."
Shut down the printer before turning it OFF.
For details on the procedure for shutting down the printer, see "Turning the Printer ON/OFF." |
USB cable*
(2) Turn the computer OFF.
(3) Disconnect the cable from the printer.
LAN cable*
(4) Disconnect the cable from the printer.
Power cord
(5) Disconnect the power plug from the AC power outlet.
(6) Disconnect the cord from the printer.
Whether the cable is connected or not varies depending on your environment.
Do not carry the printer with the paper feeder installed. If you do so, the paper feeder may drop resulting in personal injury.
For details on the procedure for installing the paper feeder, see "Installing the Paper Feeder."
USB cable*
Connect to the USB connector on the printer.
LAN cable*
Connect to the LAN connector on the printer.
Power cord
(1) Plug the power cord to the power socket on the printer.
(2) Plug the power plug in the AC power outlet.
Before removing the toner cartridge, see "Storing Toner Cartridges."
If the original box and packing materials are not available, find an appropriate box along with packing materials and pack the printer and the parts appropriately.
