» Printer Installation » Confirming the Supplied Accessories and Checking the Installation Site
Make sure that all the supplied accessories are contained in the box before installing the printer.
If an item is missing or damaged, please contact your local authorized Canon dealer.
Download the printer driver for Macintosh from the Canon Web site
The supplied CD-ROM does not include the printer driver for Macintosh. Download the printer driver for Macintosh that supports this printer from the Canon Web site (http://www.canon.com/). If you cannot find the printer driver for Macintosh that supports this printer on the Canon Web site, contact your local authorized Canon dealer.
About interface cables
This printer does not come with an interface cable. Have an appropriate one available for the computer you are using or the connecting method.
Use a USB cable with the following symbol.
About Canon Font Manager
Canon Font Manager is included in the [Canonfm] folder on the User Manual CD-ROM.
About the Supplied Manuals
The manuals supplied with this printer consist of the following. Read these manuals according to your purpose and make full use of this printer.
Manual Name
Contents
Quick Setup Guide
Explains the procedure for installing the printer.
e-Manual
Explains all the operations of this printer, such as how to use the printer and troubleshooting.
(The contents of "Quick Setup Guide" are also included.)
In order to use this printer in a safe and trouble-free manner, install the printer in a place that fulfills the following conditions.
Temperature and Humidity Conditions
Temperature range
50 to 86°F (10 to 30°C)
Humidity range
20 to 80% RH (no condensation)
Power Supply Requirements
120 to 127 V, 60 Hz
Installation Requirements
A location with sufficient space
Refer to the following dimensions of each part and ensure the installation space.
A location with good ventilation
A location with a flat, even surface
A location able to fully support the weight of the printer
051R-022
