» Managing the Printer » Register/Update Software Function » Installing the System Options/MEAP Applications
The procedures to install the system options or MEAP applications on the printer differ, depending on whether the printer is connected or not to an outside network. Select the procedure that matches your conditions using the references below.
Installing by Connecting this Printer to an Outside Network
Install from the Remote UI.
Communication test
To check that the transmission with the delivery server is properly operating, if necessary, perform a communication test before installation.
Installing by Not Connecting this Printer to an Outside Network
Installing System Options
Install using one of the following procedures.
If you install multiple system options
We recommend that you install from the Remote UI.
Procedure
Necessary Steps
Reference Page
Using the Remote UI to install
Obtain the license file from the License Management System
Install the license file using the Remote UI
Installing MEAP Applications
Use the following procedure to install.
Procedure
Necessary Steps
Reference Page
Install the license file and application file using the Remote UI
Start the MEAP applications from SMS
051R-0CE
