» Managing the Printer » Checking the Number of the Printed Pages
If you want to check the number of the printed pages, use either of the following methods.
Checking the Counter Using the Printer's Control Panel
You can check the number of the printed pages using the control panel.
1
Press [ ] (Settings).
2
Select [Check Counter] using [  ] or [  ], and then press [OK].
3
Select the counters to check using [  ] and [ ], and then press [OK].
4
Check the number of the printed pages.
Checking the Counter Using a Web Browser (Remote UI)
You can check the number of the printed pages using the Remote UI.
1
Start the Remote UI, and then log in as Administrator.
2
Select [Check Counter] from the [Status Monitor/Cancel] menu.
3
051R-0C1
