» Managing the Printer » Setting Items » [Utility Menu] Menu
[Utility Menu] Menu
About samples
For Configuration Page, Network Status Print, and Printing Position Adjustment Print, see the following.
Setting Item
Setting Value
Setting
[Check Counter]
[101: Total 1]
Check the number of pages printed.
[101: Total 1]: Number of single-sided pages printed in black and white
[Configuration Page]
Prints the capacity of the built-in memory (RAM) or the contents specified in the common [Setup] menu. You can select this item regardless of the setting for the print mode.
[Network Status Print]
Prints the version number and the settings of the print server equipped with this printer.
[IPSec Policy List]
Print the IPSec policy that is registered in the printer.
[PCL Utility]
[Font List]
A list of the fonts that can be used in the PCL mode is printed.
[PS Utility]
[Configuration Page], [Font List]
Prints the content specified in the [PS] options.
[Font List]
A list of the fonts that can be used in the PS mode is printed.
[Cleaning]
[A4], [LTR]
The printer cleans the fixing roller by printing a cleaning page.
[E-Mail Print Utility]
[Received E-Mails], [Received E-mail List]
Manage e-mail printing.
[Printing Pos. Print]
The printing position adjusted in [Adj. Start Position] is printed. Check the printout results to confirm the setting for [Adj. Start Position].
[Page Count List]
If department ID management is set, print an aggregate report of the number of pages printed by each department.
[Counter Report]
Print an aggregate report of the number of pages printed for each counter.
[Print MEAP Sys. Info]
Print information about applications installed on MEAP and parts of the system applications.
[Serial Number]
(Display only)
Displays the serial number of the printer.
[Consumables]
[Paper Information], Toner Cart. Model], [Remaining Toner]
[Paper Information]
Displays information about the loaded paper such as size, type, and remaining amount for each paper source.
[Toner Cart. Model]
Displays the model numbers of the toner cartridges.
[Remaining Toner]
Displays the amount of toner remaining in the cartridge. You can use this item to estimate when the toner cartridge will need to be replaced.
051R-0AW
