» Configuring the Network Settings (Sharing the Printer) » Network Settings for the Printer (TCP/IP) » Configuring a Computer that Performs Printing » Connecting the Printer (WSD)
If the confirmation dialog box appears during the procedure
Enter the user name and password. For more details, see the manual etc. supplied with the operating system.
1
Confirm the setting for [Receive/Print Range Setting].
Make sure that the IP address of the computer on which the printer driver is installed is not restricted to print.
If printing is restricted
You cannot install the printer driver.
If printing is restricted after the installation
If the IP address of the computer on which the printer driver is installed is restricted to perform printing in [Receive/Print Range Setting], you cannot print from the computer.
2
Install the printer driver.
Following the procedure for when you are using a WSD network environment in "Printer Driver Installation Guide", install the printer driver.
For details on the procedure for viewing "Printer Driver Installation Guide", see "Installation."
051R-090
