» Configuring the Network Settings (Sharing the Printer) » Network Settings for the Printer (TCP/IP) » Configuring a Computer that Performs Printing » Features of RAW
Features of RAW
This is a print application that can be used on Windows.
By using this printer application, you can generally print faster than when using LPD.
Advantages
You can print relatively faster than when using other applications.
When printing in Windows, the print settings using RAW are easier than using other print applications.
Disadvantage
You cannot obtain the detailed information about print jobs.
RAW is supported as standard by only Windows, not supported by Macintosh, UNIX, and Linux.
Usage Example
If you are using Windows and want to use the printer immediately after installing it
Setting Method
051R-08L
