Settings), select [Network] using [
] or [
], and then press [OK].
You can configure the settings, regardless of whether the printer is online (with the [
] ( Online) indicator turned on) or offline (with the [ ] ( Online) indicator turned off). |
] or [
] or [
], and then press [OK].|
(1):
Select [IPv4] using [
] or [ ], and then press [OK]. |
(2):
Select [On] using [
(1):
Select [IP Mode] using [
(2):
Select [Manual] using [
(1):
Select [IP Address Settings] using [
(2):
Select [IP Address] using [
(3):
Configure [IP Address].
How to enter values in [IP address]
If you are not sure what to enter in [IP Address]:
If you are not sure what values you should enter for the IP address, contact your network administrator or see "Determining Which IP Address to Assign to the Printer" for more information.
About details of hard reset
