» Useful Printing Functions » Functions Which Can Be Specified from the Control Panel
This printer allows you to specify the printing functions from the printer driver. However, some printing functions are specified from the control panel or the Remote UI. The following table shows the functions to be specified from the control panel or the Remote UI.
For details on the items you can manage using the control panel, see "Setting Items."
Function
Overview of the Function
Multi-purpose tray paper size
Specifies the size of the paper loaded in the multi-purpose tray.
Multi-purpose tray priority
Specifies whether the printer should detect the paper source in order starting with the multi-purpose tray.
Drawer N (N = 1, 2) size
Specifies the size of the paper loaded in the paper drawer (Drawer 1 or 2).
Standard paper size
Since paper size cannot be specified when printing from DOS, UNIX or other operating system, specify it using this setting.
Invalid paper tray
Specifies what the printer does when paper that is the same size as the paper size of the received data is not loaded in the selected paper source.
Auto selection
Specifies the paper source to be automatically selected.
Standard paper type
Since paper type cannot be specified when printing from DOS, UNIX or other operating system, specify it using this setting.
Adjust Print Position
Adjusts the printing position in the vertical direction (Y) or the horizontal direction (X).
Alternative method
If the last page for the 2-sided printing is 1-sided printing, 1-sided printing is applied to the last page.
Image Refinement
Set whether to use the smoothing process to print the jagged edges of text and graphics.
Recovery printing
Specifies whether to print the partially printed page when the printer stops printing due to a paper jam or an error occurring.
Check paper size
Specifies whether the printer should stop printing, displaying the message <Check paper size.> or continue printing.
Substitute size
The printer switches the paper size if the paper of the size to be used is not loaded in the printer.
Plain paper curl adjustment
If printed plain paper curls, specify the setting for this item.
051R-062
