» Useful Printing Functions » Printing from a Computer (Windows) » 1-sided Printing and 2-sided Printing » Attention (1-sided Printing and 2-sided Printing)
Paper loading orientation
On 2-sided printing, the back side of the paper is printed first, therefore the paper should be loaded in the opposite orientation to that for 1-sided printing.
If printing on such paper with letterheads, in which faces and directional orientations are specified, see "Paper Loading Orientation" and load the paper in the proper orientation.
In the case where the last page is 1-sided printing
In cases such as where the last page for the 2-sided printing is 1-sided printing, specifying the following setting allows you to print faster than normal 2-sided printing.
Press [  ] (Settings).
Select [Layout] using [  ] and [  ], and then press [OK].
Select [Alternative Method] using [  ] and [  ], and then press [OK].
4.
Select [On] using [  ] and [  ], and then press [OK].
However, when performing 2-sided printing on punched paper or previously printed paper, the orientation or printing surface of the last page may differ from other pages. In this case, set to [Off].
051R-050
