» About This Printer » Introduction of the Optional Accessories
The following optional accessories are available to make full use of the printer functions.
For the optional accessories, contact your local authorized Canon dealer.
Paper Feeder
You can load up to 500 sheets of plain paper (19.9 lb Bond (75 g/m²)) of the following sizes in the paper feeder.
Standard sizes
A4, B5, A5, A6, Legal, Letter, and Executive
Custom paper sizes
Width 4.13 to 8.50 in. (105.0 to 215.9 mm), Length 5.83 to 14.00 in. (148.0 to 355.6 mm)*
If you are using the UFR II printer driver, you can load custom size paper that is 5.83 to 8.50 in. (148.0 to 215.9 mm) wide and 5.83 to 8.50 in. (148.0 to 215.9 mm) long in landscape orientation.
Paper Feeder Unit PF-44
Use a paper feeder designed for this printer.
Be sure to use a paper feeder designed for this printer.
How to install the paper feeder
Barcode ROM
The following function is available by installing Barcode Printing Kit-F1.
<Bar code fonts for bar code printing>
OCR-B
Symb. FontInform
Symbole stethos
BarDIMM ©1997
USPS ZEBRA+4Stat
How to install Barcode Printing Kit-F1
SD Card
You can use an SD card that can be built in the printer to save the received print jobs temporarily. By installing the SD card, you can use various functions such as print job spooling, encrypted secured print, secured print, and electronic sort.
How to install the SD card
051R-012
