Offset Short Edge/Offset Long Edge (Front)
-2.00 inches to +2.00 inches; 0.00* inches
This setting enables you to set the offset position in inches. The settings can be set in increments of 0.01" from -2.00" through +2.00".
The print position on the front page is adjusted in the vertical or horizontal direction to the value specified in the setting value.
To adjust the print position on the back page, set the Offset Short Edge/Offset Long Edge (Back) mode (the next setting).
You can increase or decrease the setting in increments of 0.01" to adjust the print position, as described below.
[Offset Short Edge (Front)]
Increasing the setting value moves the image in the rightward X direction on the paper. Decreasing the setting value moves the image in the leftward X direction on the paper.
[Offset Long Edge (Front)]
Increasing the setting value moves the image in the downward Y direction on the paper. Decreasing the setting value moves the image in the upward Y direction on the paper.
The print position on the back page is adjusted in the vertical or horizontal direction to the value specified in the setting value.
To adjust the print position on the front page, set the Offset Short Edge/Offset Long Edge (Front) mode (the previous setting).
[Offset Short Edge (Back)]
[Offset Long Edge (Back)]
Pressing  increases the gutter setting value by 0.01" each time the key is pressed. Pressing  decreases the value by 0.01" each time. Holding down either  or  continuously speeds up the value alteration.
Pressing  increases the offset position setting value by 0.01" each time the key is pressed. Pressing  decreases the value by 0.01" each time. Holding down either  or  continuously speeds up the value alteration.
