Fixing Station (Inside the Main Unit)
If a paper jam occurs in the fixing station, a screen prompting you to remove the jammed paper appears on the touch panel display. Check the location of the paper jam, and follow the procedure described below, while referring to the directions that appear on the touch panel display, to remove the jammed paper.
» Problem Solving » Clearing Paper Jams » Fixing Station (Inside the Main Unit)
0S9Y-1R5
