Between the Main Unit and the POD Deck (Optional)
If a paper jam occurs between the main unit and the POD Deck-D1, or between the main unit and the POD Deck Lite-C1, a screen prompting you to remove the jammed paper appears on the touch panel display. Check the location of the paper jam, and follow the procedure described below, while referring to the directions that appear on the touch panel display, to remove the jammed paper.
To clear a paper jam which occurs in the POD Deck Lite-C1 side, refer to "POD Deck Lite-C1 (Optional)."
» Problem Solving » Clearing Paper Jams » Between the Main Unit and the POD Deck (Optional)
0S9Y-1R1
