CAUTION |
When closing the cover, be careful not to get your fingers caught, as this may result in personal injury.
CAUTION |
When reconnecting the POD Deck Lite-C1 to main unit, be careful not to get your fingers caught, as this may result in personal injury.
When reconnecting the POD Deck Lite-C1 to the main unit, confirm that the front cover of the main unit is closed properly.
The inside lifter automatically descends to the paper loading position.
If the machine is in the Sleep mode (the touch panel is not displayed, and only
(Energy Saver) is lit), you may be unable to open the paper deck unit. In this case, press (Energy Saver) to reactivate the machine, and then press the open button on the paper deck unit. |
CAUTION |
When closing the paper deck, be careful not to get your fingers caught, as this may result in personal
injury. |
When closing the paper deck, confirm the followings:
Paper is loaded properly.
The size change plates and rear edge retainer are set in the proper position.
The screen indicating the directions on how to clear the paper jam is displayed repeatedly until the paper jam is cleared.
