Image Orientation When Output with External Finisher
You can change the output image orientation for delivering paper from the High Capacity Stacker-H1 to the external finisher.
This mode can be set if the High Capacity Stacker-H1 and the external finisher are attached.
(See "High Capacity Stacker-H1.")
Press
(Settings/Registration).
Press [Function Settings] → [Common] → [Paper Output Settings].
Press [Image Orient. When Output with Extrnl. Fin.].
4.
Select [Do Not Rotate] or [Rotate 180 Degrees] → press [OK].
Details of each item are shown below.
[Do Not Rotate]:
Paper is output with the top edge of the paper at the back of the tray.
[Rotate 180 Degrees]:
Paper is output with the top edge of the paper at the front of the tray.
