Normal/Reverse Order Output with External Finisher
You can change the output order for delivering paper from the High Capacity Stacker-H1 to the external finisher.
This mode can be set if the High Capacity Stacker-H1 and the external finisher are attached.
(See "High Capacity Stacker-H1.")
Press
(Settings/Registration).
Press [Function Settings] → [Common] → [Paper Output Settings].
Press [Normal/Rvrse. Order Output with Extrnl. Fin.].
4.
Select [Normal Order] or [Reverse Order] → press [OK].
Details of each item are shown below.
[Normal Order]:
Paper is output from the first page.
[Reverse Order]:
Paper is output from the last page.
