Inserting a Job Separation Sheet after Clearing a Paper Jam in the Stacker
0S9Y-12E
When you restart a print job after clearing a paper jam in the stacker, this mode enables you to insert a blank page before the first page of each print job from a selected paper deck.
This mode can be set if the High Capacity Stacker-H1 is attached.
(See "High Capacity Stacker-H1.")
Press
(Settings/Registration).
Press [Function Settings] → [Common] → [Paper Output Settings].
Press [Job Separator After Remov. Stacker Ppr. Jam].
4.
Press [On] → [OK].
Select [Off] if you do not want to insert a job separation sheet after clearing a paper jam in the stacker.
To change the paper deck for the job separation sheets, press [Change] → select the paper deck → press [OK].
