Specifying the Maximum Number of Sheets to Load in the Stacker
You can specify the maximum number of sheets to load in the stacker.
This mode can be set if the High Capacity Stacker-H1 is attached.
(See "High Capacity Stacker-H1.")
Press
(Settings/Registration).
Press [Function Settings] → [Common] → [Paper Output Settings].
Press [Specify Max No. of Sheets to Load in Stacker].
4.
Press [OK].
Select [Off] if you do not want to specify the maximum number of sheets to load in the stacker.
5.
Press [-] or [+] to specify the number of sheets to load the stacker → [OK].
Up to 3000 sheets can be specified.
If the number of sheets is set at almost limit of loading, printing may stop before reaching the loading limit you specify due to paper conditions such as curled paper or the paper thickness.
