(Quick Menu), is called the Quick Menu screen. The following keys are displayed on the Quick Menu screen.
1
[Personal]
Press to display the buttons registered as Personal buttons. [Personal] is displayed only when Department ID Management is set.
2
[Shared]
Press to display the buttons registered as Shared buttons.
3
![]() Press to edit the Quick Menu screen.
You can specify the following settings:
[Change Button Size to Small]/[Change Button Size to Large]
[Wallpaper Settings]
[Edit Buttons]
[Restrict Quick Menu Use]
4
Personal button/Shared button Display Area
The registered Personal buttons/Shared buttons are displayed in this area.
5
[Log Out]
Press to log out.
If you are logged in using Department ID Management, [Log Out] is displayed.
Icon
Function Type
Copy
Scan and Send
Scan and Store
Shortcut to the Stored Folders
(Quick Menu).
Press
(Main Menu) to return to the Main Menu screen. |
If Department ID Management is not set, the Log in screen is not displayed. For more information on Department ID Management, see "Department ID Management."
