Setting the Memory Lock Mode
You can set to store received I-fax documents in the Memory RX Inbox without printing them. You can later check the received documents in the Memory RX Inbox, and print or send them as necessary.
If you set [Use I-Fax Memory Lock] to 'On', you can set <I-Fax Memory Lock> for the Memory RX Inbox to 'On' or 'Off' as necessary. (See "Specifying the I-Fax Inbox Settings" and "Receiving Files Through I-Fax.")
You cannot store received documents in memory in the cases below. (These numbers may vary depending on the remaining capacity of the hard disk.)
When a total of 1,500 files are stored in the Mail Box and Fax/I-Fax Inbox
When a total of 6,000 pages of documents are stored in the Mail Box and Fax/I-Fax Inbox
When there is insufficient memory available
To receive documents in memory, you must first set [Use I-Fax Memory Lock] to 'On' in [Set Fax/I-Fax Inbox] in [Common Settings] in [Receive/Forward] in [Function Settings] (Settings/Registration). (See "Specifying the I-Fax Inbox Settings.")
» Scan and Send » Receiving I-Fax Documents » Setting the Memory Lock Mode
0S9Y-0KU
