e-ManualTopSite mapHelp
Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in a Mail Box
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Limited Color PDF
Searchable PDF/XPS/OOXML
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Applying a Policy
Selecting the Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Job Done Notice
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Top » Scan and Send » Storing New Addresses » Checking/Editing/Deleting a Stored Address
0S9Y-0J4
You can change stored address details as necessary. However, you can only edit destinations stored in the Local Address Book.
Checking/Changing Information for Stored Addresses
Press (Main Menu) → [Scan and Send] → [Address Book].
Press [Register /Edit].
Select the destination to edit → press [Details/ Edit].
For instructions on searching for registered destinations, see "Address Book Screen."
4.
Edit each setting as necessary.
You cannot change the Address List of a group address or a destination registered in the group address.
For instructions on registering an e-mail address, see "Registering an E-Mail Address."
For instructions on registering an I-fax address, see "Registering an I-Fax Address."
For instructions on registering a file server address, see "Registering a File Server Address."
For instructions on registering a group address, see "Registering a Group Address."
5.
Press [OK] → [Close] → [Cancel].
If you are managing Address Book access numbers, perform the procedure in step 11 of "Registering an E-Mail Address."
Deleting Addresses
Select the destination to delete → press [Delete].
4.
Press [Yes].
5.
Press [Close] → [Cancel].
