This mode can be used only for printing a file stored in a mail box.
(Main Menu) → [Access Stored Files] → [Mail Box].
[Upright Image]:
Prints the image upright on the paper.
[Sideways Image]:
Prints the image sideways on the paper.
Upright Image
Sideways Image
If you set any two of [Copy Set Numbering], [Watermark], or [Print Date] to print in the same position, a confirmation message appears when you press
(Start). |
(numeric keys).|
You can specify between '2' and '5' digits.
Example:
If the page number is 10, and the number of digits is 2: 10 → 10
If the page number is 10, and the number of digits is 5: 10 → 00010
If the specified number of digits is less than the number of digits of the actual page number, the setting is invalid.
Printing performance may not be optimal, depending on the file content and combination of settings.
If you use [Page Numbering] with [Add Cover], [Insert Sheets], or [Job Separator], numbers will not be printed on the inserted pages.
The Superimpose Image mode cannot be used with files including images with resolutions of less than 600 x 600 dpi.
If you select [With Chapter Numbers] in combination with the Sheet Insertion or Job Separator mode, the chapter numbers are counted at the following times:
After each chapter page is inserted
After each sheet insertion is inserted
