e-ManualTopSite mapHelp
Top » Access Stored Files » Overview of This Function
0L3X-15H
You can print files stored in the following storage locations:
Mail Box
Memory Media
To print a stored file, press [Access Stored Files] on the Main Menu screen → specify the location where the desired file is stored.
Mail Box
The Mail Box is a data storage location in the machine that stores and handles files for printing in a format exclusively supported by this machine.
It enables users to store files that are scanned with this machine, or data sent from a personal computer via the printer driver. You can print the stored document whenever necessary using the desired settings. Also, you can convert the file format of documents to another format, such as PDF, to send via e-mail or fax using the Send function.
You can use up to 100 mail boxes and assign a name or set a PIN for each mail box. In addition, various editing features are available, such as merging separately stored files into one file, and erasing unnecessary pages from a file.
Memory Media
Memory media is a storage location that can be used by connecting USB memory to the USB port of the machine. You can scan a document with this machine and store it in memory media in various file formats that can be used on your computer. You can also print files stored in memory media on this machine at any time with your desired print settings.
For more information on the optional products required to view/print PDF files from this machine, see "Optional Products Required for Each Function."
If the USB Device Port-A3 and Multimedia Reader/Writer-A3 are installed, you can use SD cards, Memory Sticks, CF cards, and Microdrives as memory media. For more information, see "USB Device Port-A3" and "Multimedia Reader/Writer-A3."
For instructions on inserting/removing memory media, see "Inserting and Removing Memory Media."
The following memory media file system is supported:
Type: USB memory
File System: FAT32
Devices such as the following are not supported:
Memory media with security functions
Memory media that does not meet the USB specification
Memory card readers connected via USB
Usage methods such as the following are not supported:
Connecting memory media via an extension cable
Connecting memory media via a USB hub
Some memory media cannot be used.
Types of Mail Box Icons
As shown in the table below, icons indicates the color mode used when the file was stored and whether it was stored with print settings.
The icons for files stored from a computer or using [Store in Mail Box] of the Copy function, or files with print settings, become icons with print settings. However, if you use the file editing modes, [Merge Multiple Files] or [Insert Pages] with these files, the newly created files have icons for files without print settings.
Icon
Types of Files
Color/Black & White
Without Print Settings
"Black and White"
With Print Settings
"Black and White"
"Color" or "Mixed"
RGB
With Print Settings
"Color" or "Mixed"
RGB
"Black and White"
CMYK*1
With Print Settings
"Black and White"
CMYK*1
"Color" or "Mixed"
CMYK*1
With Print Settings
"Color" or "Mixed"
CMYK*1
*1 If the file is stored in a mail box from the PS printer driver, the color format will be CMYK. The CMYK files cannot be sent. To print full color CMYK files, only [Auto (Color/B&W)] can be specified. To print black CMYK files, [Black & White] can also be specified.
Types of Memory Media Icons
The table below shows the types of files that can be used in the memory media, as well as the icons used for each file type.
Icon
Type of File
JPEG file
TIFF file
PDF file
XPS file
OOXML file
