e-ManualTopSite mapHelp
Top » Status Monitor/Cancel » Checking the Paper Information
0L3X-1ES
You can check the detailed paper information. You can also register/set the paper type to load in a paper source, such as a paper drawer.
Press (Status Monitor/Cancel).
Press [Paper].
To check the details of paper loaded in the machine:
To set a paper type:
To register a paper type:
Select the paper you want to check → press [Details].
Press [OK].
Press [Paper Settings].
Select a paper source to set → set the paper type to load.
For instructions on specifying [Paper Settings], see "Registering the Paper Size and Type for a Paper Source."
Press [Paper Type Management Settings].
Register a user-defined paper type.
[Paper Type Management Settings] is displayed when you log in as an administrator.
For instructions on specifying [Paper Type Management Settings], see "Overview of This Function."
Press [OK].
Press [Close].
