e-ManualTopSite mapHelp
Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in a Mail Box
Storing in an Advanced Box
Setting Your Personal Folder as the Destination
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Limited Color PDF
Searchable PDF/XPS/OOXML
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Applying a Policy
Selecting the Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Job Done Notice
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Top » Scan and Send » File Name
File Name
0L3X-13E
You can set a file name to use when sending a document to an e-mail, I-fax, file server. or mail box destination. If you do not specify a file name, it will be specified automatically.
Press (Main Menu) → [Scan and Send].
Specify the destination → press [Options] → [File Name].
Press [File Name].
4.
Enter a file name → press [OK] → [OK].
If you are sending to an e-mail address or file server, specify [Auto (OCR)] as necessary.
If you set [OCR (Text Searchable)] for [PDF], [XPS], [OOXML] as the file format, you can set [Auto (OCR)] to 'On' to automatically name the file with extracting first text block which is detected as the document title. You can set the number of characters that are extracted for [Auto (OCR)] in <No. of OCR File Name Characters> in OCR (Text Searchable) Settings. (See "Settings for Creating Searchable PDF/XPS/OOXML.")
The desired text block may not be set as the file name depending on the layout of the document, etc.
Characters, such as commas (,), slashes (/), or brackets ([,]) are invalid when sending a file and will not be extracted as the file name.
If you have already entered a document name, the extracted text block is appended to the end of the file name. Characters over the character limit will be cut off.
You cannot set the encrypted PDF mode and [Auto (OCR)] at the same time.
When you send documents via e-mail or I-fax, each page is sent as a separate image attached to an e-mail message or a separate TIFF image attached to an I-fax. The file extension for the document matches the file format that you select for sending. The file name is assigned as follows:
If you set the file name:
The file name is composed of the file name as entered, plus three digits that represent the page number of the image.
Example: file name_002.tif
If you do not set the file name:
The file name is composed of the job number (0001 to 4999), plus three digits that represent the page number of the image.
Example: 1231_002.tif
When you send documents to a file server, each page is sent and stored as a separate image. The file extension for the document matches the file format that you select for sending. The file name is assigned as follows:
If you Divide into Pages:
The file name is composed of the file name as entered, the year, month, day, hour, minute, and second the file is sent, and five digits that represent the page number of the image.
Examples:
file name_20140707203000_00002.tif
file name_20140707203000_00002.pdf
file name_20140707203000_00002.xps
If you do not Divide into Pages:
The file name prefix is generated by the file name and the year, month, day, hour, minute, and second the file is sent.
Examples:
file name_20140707203000.tif
file name_20140707203000.pdf
file name_20140707203000.xps
The file name prefix is generated by the year, month, day, hour, minute, and second the file is sent, and the five digits that signify the page number of the image.
Examples:
The file name is composed of the year, month, day, hour, minute, and second the file is sent.
Examples:
20140707203000.tif
20140707203000.pdf
20140707203000.xps
You can specify a file name using the Remote UI when sending to an e-mail/I-fax address or a server that is stored in [Favorite Settings]. (See "Specifying a File Name for Transmission to a Destination in Favorite Settings.")
5.
Press [Close].
If you use characters such as backslashes (\), slashes (/), colons (:), asterisks (*), question marks (?), double quotation marks ("), open angle brackets (<), close angle brackets (>), and vertical bars (|) in the document name, you are unable to send the file to file servers that run on operating systems that do not recognize such characters.
