For information on the types of administrators, see "Administrator Settings."
Settings in [Adjustment/Maintenance] (Settings/Registration) cannot be set from the Remote UI.
System Manager/System Administrator (Administrator)
Network Administrator (NetworkAdmin)
Device Administrator (DeviceAdmin)
[Restart Device]
[Paper Settings]
Paper Type Management Settings
[Display Settings]
Edit Puncher Unit Die Name
[Timer/Energy Settings]
Date/Time Settings
Time Format
Quick Startup Settings for Main Power
Restrict Auto Reset Time
[Network Settings]
TCP/IP Settings
IPv4 Settings
IPv6 Settings
WINS Settings
LPD Print Settings
RAW Print Settings
SNTP Settings
FTP Print Settings
WSD Settings
FTP PASV Mode Settings
IPP Print Settings
Multicast Discovery Settings
HTTP Settings
SSL Settings
Proxy Settings
Department ID PIN Confirmation Settings
IPSec Settings
NetWare Settings
AppleTalk Settings
SMB Server Settings
SNMP Settings
Dedicated Port Settings
Spooler
Waiting Time for Connection at Startup
Ethernet Driver Settings
IEEE 802.1X Settings
Firewall Settings
IPv4 Address Filter
IPv6 Address Filter
MAC Address Filter
IP Address Block Log
[External Interface]
USB Settings
[Common Settings]
Paper Output Settings
Normal/Rvrse. Order Output with Extrnl. Fin.
Face Up/Face Down Output with Extrnl. Fin.
Image Orient. When Output with Extrnl. Fin.
Print Settings
Copy Set Numbering Option Settings
Generate File
Rights Management Server Settings
Set Authentication Method
[Copy]
Select Color Settings for Copy
[Printer]
Restrict Printer Jobs
PDL Selection (Plug and Play)
[Send]
Common Settings
Confirm SSL Certificate for WebDAV TX
Restrict Resending from Log
TX Report/Communication Management Report
TX Report - Attach TX Image to Report
TX Report - Attach Color TX Image to Report
Network Settings - E-Mail/I-Fax Settings
Confirm SSL Certificate for POP RX
Confirm SSL Certificate for SMTP TX
Communications Settings - E-Mail/I-Fax Settings
Limit New Destination
Only Send E-Mail to Myself
Only Send File to Personal Folder
Personal Folder Specification Method
TX Settings - Fax Settings
Restrict Sequential Broadcast When Fax Destination Included
Confirm Before Sending When Fax Destination Included
Fax TX Report/Fax Activity Report
Fax TX Report - Attach TX Image to Report
PIN Code Access
Confirm Entered Fax Number
Remote Fax TX Settings
[Receive/Forward]
Common Settings
Interrupt and Print RX Jobs
Handle Files with Forwarding Errors
Divided Data RX Timeout/Always Send Notice for RX Errors
Forwarding Settings
Memory Lock Settings
[Store/Access Files]
Settings for All Mail Boxes
Box Security Settings
Memory Media Settings
[Secure Print]
[Address Book PIN]
[Manage Address Book Access Numbers]
[Address Book Export Settings]
[Register LDAP Server]
[Register/Edit LDAP Search]
[Acquire Remote Address Book]
[Make Remote Address Book Open]
[User Management]
System Manager/Contact Person Information Settings
Department ID Management
[Device Management]
Device Information Settings
Certificate Settings
Key and Certificate Settings
CA Certificate Settings
Certificate Revocation List (CRL) Settings
Display Job Status Before Authentication
Display Job Log
Save Audit Log
Export/Clear Audit Log
Key Operation Log Store Settings
Encryption Method Settings
[License/Other]
Message Board/Support Link
Remote UI Settings
Remote Operation Settings
MEAP Settings
Register/Update Software
[Data Management]
Hard Disk Data Complete Deletion
Import/Export All
Import
Export
Import/Export Results
Import/Export Individually
Address Lists
Device Settings (Forwarding Settings, Address Book, Send Function Favorite Settings)
Web Access Favorites
Printer Settings
Paper Information
Back Up/Restore Settings
Backup Location Settings
Auto Backup Settings
Back Up
Restore
Back Up/Restore Log
