Managing Confidential Fax Inboxes
Click [Access Received/Stored Files] → [Confidential Fax Inbox] → select the number of the desired inbox.
If the desired inbox is set with a PIN, enter the PIN → click [OK].
You can also select the desired inbox by entering its number next to <Box Number (00-49)> → click [Open...].
Change the settings of the selected Confidential Fax Inbox, or select an operation to be performed for a document in the Confidential Fax Inbox.
To change the settings of the selected Confidential Fax Inbox:
Click [Settings] → specify the desired settings → click [OK].
Select the documents that you want to print → click [Print...] → [Start Printing].
If you want the documents to be automatically deleted after they are printed, select [Delete File After Printing].
Select the documents that you want to delete → click [Delete].
Once a document is deleted, it cannot be retrieved.
To display the details of a document:
Click the destination.
You can also click an icon in Type to display the document details.
Displayed Icon:
Forwarded I-fax document or I-fax document saved in memory.
