e-ManualTopSite mapHelp
Top » Flow of Settings » Using the Machine as a Scanner
0L3X-00J
The following operations and settings are required to use the machine as a scanner.
For information on the system requirements for installing the scanner driver, see "System Requirements."
1. Connect the machine to the network.
2. Set the machine to use the TCP/IP network.
3. Install the software for specifying scanner settings (Network ScanGear) into the computer connected to the machine.
