e-ManualTopSite mapHelp
Top » Flow of Settings » Operations Required Prior to Using the Machine
0L3X-008
This section describes the flow of operations and settings required prior to using the machine, for the functions you will use.
Confirm the Following Settings
Some functions of the machine require optional products and operations/settings.
Also, if you want to use functions that require license registration, see "Adding New Functions." See the flowcharts in this category for functions that require operations or settings.
For information on optional products, see "Optional Products Required for Each Function."
For information on the system requirements for using the following functions, see "Optional Equipment and System Requirements."
Printing from a Computer for Printing (USB/network)
Using E-Mail/I-Fax for Scanning and sending (via e-mail/I-fax)
Sending Data for Scanning and sending (to a file server)
Function
Optional Product Required
License Registration
Operations Required
Copy
Duplex Color Image Reader Unit-H1
None
Scanning and Storing Files
Mail Box
None
Memory Media*2
Accessing Stored Files
Mail Box
None
None
Memory Media*2
None*1
Scanning and Sending Files
E-Mail/I-Fax
Sending Files to File Servers
Fax
Sending and Receiving Files via the Remote Fax Server
Remote Fax Kit
Required
Print
UFR II Print
imagePRESS Printer Kit
Required
PCL Print
Required
PS Print
imagePRESS Printer Kit or imagePRESS PS Printer Kit
Required
Barcode Print
Barcode Printing Kit and imagePRESS Printer Kit
Required
Direct Print
Required
Remote UI
None
MEAP Management Function (SMS)
None
Registering/Updating Software (Delivery)
None
Registering/Updating Software (Manual)
None
Scanning
*1
To print PDF files, the imagePRESS Printer Kit or imagePRESS PS Printer Kit is required.
*2
The default setting for displaying Memory Media is 'Off'. To use memory media, press [Display Settings] in [Preferences] (Settings/Registration) → set <Memory Media> in [Store Location Display Settings] to 'On'.
