[Upright Image]:
Press this if you are placing originals upright.
[Sideways Image]:
Press this if you are placing originals sideways.
Upright Image
Sideways Image
Vertical Placement
Horizontal Placement
Vertical Placement
If you set any two of [Page Numbering], [Copy Set Numbering], or [Print Date] to print in the same position, a confirmation message appears when you press (Start).
Text that you enter in [Custom] is not automatically saved. If you want to register text to be selected with watermarks whenever necessary, press [Register] → enter the text to be registered.
You can also select text that has been registered in [Register Characters for Page No./Watermark]. (See "Registering/Editing/Deleting User-Defined Text for Page Numbers and Watermarks.")
Printing performance may not be optimal, depending on the original content and combination of settings.
If you use [Watermark] with [Add Cover] or [Insert Sheets], numbers will not be printed on the inserted pages.
