[Upright Image]:
Press this if you are placing originals upright.
[Sideways Image]:
Press this if you are placing originals sideways.
Upright Image
Sideways Image
Vertical Placement
Horizontal Placement
Vertical Placement
If you set any two of [Copy Set Numbering], [Watermark], or [Print Date] to print in the same position, a confirmation message appears when you press (Start).
If [With Page Total] is used with the Booklet mode, the total number of pages are printed automatically.
You can specify a number of digits between '2' and '5'.
Example:
If the page number is 10, and the number of digits is 2:10 → 10
If the page number is 10, and the number of digits is 5:10 → 00010
If the specified number of digits is less than the number of digits of the actual page number, the setting is invalid.
Printing performance may not be optimal, depending on the original content and combination of settings.
If you use [Page Numbering] with [Add Cover] or [Insert Sheets], numbers will not be printed on the inserted pages.
If you select [Insert Sheets] in combination with the or Insert Sheets mode, the chapter numbers are counted at the following times:
After each chapter page is inserted
After each sheet insertion is inserted
