Adjusting Density Manually
You can manually adjust the density to the most appropriate level for the original.
Setting Density Before Copying
Press (Main Menu) → [Copy].
Press [Options] → [Density].
Press or to adjust the density for the original → press [OK].
The density becomes lighter as the indicator is moved to the left and darker as the indicator is moved to the right.
4.
Press [Close].
Setting Density During Copying
Press or to adjust the density for the original.
If you change the density in [Options], adjusting the density during copying may not have any effect on the output.
If you want to adjust the background density, see "Adjusting Background Density."
» Copy » Adjusting Density Manually
0L3X-0WR
