When using [1-Sided
![]() ![]() Only LTR paper can be used for [Book
![]() Place your originals on the platen glass when using [Book
Make sure to align your original correctly when copying in [2-Sided]. Align the top edge of the original with the back edge of the platen glass (by the arrow in the top left corner), or with the back edge of the feeder.
Place your originals in the feeder when using [2-Sided
If [Auto Collate] is set to 'On', the Collate or Offset Collate mode is automatically set when you place your originals in the feeder. (See "Enabling Auto Collating.")
To make copies in the correct page order when using [Book
[Book Type]:
The front and back sides of the copy will have the same top-bottom orientation.
[Calendar Type]:
The front and back sides of the copy will have opposite top-bottom orientations.
[Book Type]:
The front and back sides of the original have the same top-bottom orientation.
[Calendar Type]:
The front and back sides of the original have opposite top-bottom orientations.
[Book Type]:
[Calendar Type]:
[Book Type]:
[Calendar Type]:
[Left/Right
Copies the facing pages of a book or bound original onto the front and back sides of a single sheet of paper.
[Front/Back
Copies the front and back sides of the left page or the right page onto both sides of a single sheet of paper.
The original is placed face down on the platen glass.
[Left Opening Book]
[Right Opening Book]
The original is copied from right to left.
The original is copied from left to right.
For information on the optional products required to use [2-Sided
To copy the next two facing pages when using [Book
You may not be able to copy using this mode, depending on the paper quality.
Paper used to make two-sided prints must conform to the following specifications:
Paper size: 13" x 19", 12" x 18", 12 5/8" x 17 11/16", 11" x 17", LGL, LTR, LTRR, STMTR, EXEC, and Custom Size (4" x 5 7/8" to 13" x 19 1/4" (100 mm x 148 mm to 330.2 mm x 487.7 mm)), except for transparencies, clear film, labels, tab paper, or envelopes
Paper weight: 14 lb bond to 110 lb cover (52 to 300 g/m2)
When using [1-Sided
![]() If you use [1-Sided
![]() When placing your originals on the platen glass to copy with [2-Sided
![]() If you want to place your two-sided original on the platen glass to copy with [2-Sided
![]() If you select the Front/Back 2-Sided mode when copying with [Book
![]() If you use paper less than 16 lb bond (60 g/m2) in weight for two-sided printing when a finisher is attached, the output paper may not be aligned.
