e-ManualTopSite mapHelp
Top » Adjustment for Image Quality and Finishing (Calibration) » Adjust Action » Adjusting the Paper Folding Position
0L3X-0KU
You can adjust the folding positions of the paper when a folding mode is set.
The saddle fold positions can be adjusted when the Saddle Finisher-AM2 or the Booklet Finisher-T1 is attached. (See "Finisher-AM1/Saddle Finisher-AM2/Puncher Unit-BS1/Puncher Unit-BT1," "Staple Finisher-T1/Booklet Finisher-T1/External 2/3 Hole Puncher-C1/External 2/4 Hole Puncher-C1/External 4 Hole Puncher-C1.")
The C-fold, Z-fold, half fold, accordion Z-fold, or double parallel fold positions can be adjusted when the Paper Folding Unit-F1 is attached. (See "Paper Folding Unit-F1.")
Press [Adjustment/Maintenance] → [Adjust Action] → [Adjust Fold Position].
Select the method for the folding position of paper.
To adjust the position of the Saddle Folding, select the paper size you want to change.
4.
Adjust the folding position by pressing [] or [] → press [OK].
If you selected [Adjust Double Parallel Fold Position], adjust the two folding positions (A and B).
