      0WR6-0J1
      <Mail Box Settings>
      You can specify the settings for the Mail Box.
      Item
      Description
      <Set/Register Mail Boxes>
      You can set a password and name for a box as well as specify the period of time before files in a box are automatically deleted. Specifying the Mail Box Settings
      IMPORTANT:
      Since there is no way to check a registered password, make sure that you write down the password that you enter, and keep it in a safe place.
      Setting Value
      <Register Box Name>: Register a box name.
      <PIN>: Enter a password.
      <Time Until File Auto Delete>: 0 to 12 hr., 1 to 3 to 30 days
      <URL Send Settings>: Select a destination from the Address Book.
      <Print When Storing from Printer Driver>: <On>, <Off>
      <Initialize>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: No
      You can specify the settings of <Time Until File Auto Delete> and <Print When Storing from Printer Driver> in <Set/Register Mail Boxes> for all boxes at the same time.
      You can restrict the printing operations for files to be stored in the Mail Box, enhancing a security.
      <Photo Printout Mode>
      You can select whether to use the Photo Printout mode. If <On> is selected, you can select <Printed Image> or <Photo Printout> on the <Original Type> screen to adjust image quality.
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Can be set in the Remote UI: No
