      0WR6-08Y
      Saving Documents in the Mail Box
      There are two methods for saving documents in the Mail Box: scanning documents from the machine and sending files on a computer from the printer driver. Scanned documents are saved with the print settings when saved from <Store in Mail Box> in the <Copy> function or from a printer driver, allowing you to always print documents with the same finishing, as well as saving you the trouble of specifying settings.
      Scanning from the Machine to Save
      1
      Set the document. Placing Documents
      2
      Press <Scan and Store> on the Main Menu. <Main Menu> Screen
      3
      Press <Mail Box>.
      4
      Select the box to save in.
      For information on the items on the screen and instructions on how to use them, see Editing Files in the Mail Box.
      5
      Press <Scan>.
      6
      Specify the scan settings as necessary.
      7
      Press .
      Documents are scanned and saved as files.
      To cancel scanning, press <Cancel> or   <Yes>.
      When <Press the [Start] key to scan the next original.> is displayed
      Saving Data on Computers
      1
      Open a file and display the print screen.
      2
      Select the machine and click [Preferences] or [Properties].
      3
      Select [Store] from [Output Method] and click [Yes].
      4
      Specify the detailed settings for saving and click [OK].
      [Data Name]
      To save using the file name of the data on the computer, select [Use File Name]. To change the file name, select [Enter Name] and enter a file name in the [Name] text box.
      [Mail Boxes]
      Select the box you want to save in. Clicking while holding down the [CTRL] key on the computer keyboard enables you to select multiple boxes and save the same files in each box.
      NOTE:
      The box name registered in the machine can be applied to the printer driver. For details, see Help of the printer driver.
      5
      Specify the print settings as necessary and click [OK].
      6
      Click [Print] or [OK].
      The file is saved in the box selected in step 4.
      1
      2
      Select the machine and specify the print settings.
      3
      Select [Store] in [Job Processing] of [Special Features] panel.
      4
      Click [Print].
      5
      Specify the detailed settings for saving.
      [Document Name]
      Enter the name of a file to save in the box.
      [Mail Boxes]
      Select the box you want to save in. Clicking while holding down the [COMMAND] key on the computer keyboard enables you to select multiple boxes and save the same files in each box.
      6
      Click [OK].
      The file is saved in the box selected in step 5.
