      0WR6-0A0
      Configuring the Authentication Functions
      You can configure the user login methods, authentication devices, and other authentication functions based on your system environment and needs. You can also specify how the login screen is displayed.
      Configuring the User Login Methods and Authentication Devices
      Specify the user login methods (Login Method) and authentication devices (Authentication Device). Note that the authentication devices need to be set up before configuring the settings below.
      1
      Start the Remote UI. Starting the Remote UI
      2
      Click [Settings/Registration] on the portal page. Remote UI Screen
      3
      Click [User Management]  [Authentication Management].
      4
      Click [Basic Settings]  [Edit].
      5
      Select the check box for [Use the user authentication function] and specify the required settings.
      Select the login methods that you want to use, and specify detailed settings such as for the authentication devices.
      Using IC card authentication
      Using keyboard authentication
      Configuring detailed settings for authentication functions
      6
      Click [Update].
      7
      Restart the machine. Restarting the Machine
      The authentication method selected for [Web Service Authentication Method] is also used for personal authentication during the device information distribution. Performing User Authentication when Distributing Device Information
      Specifying When to Display the Login Screen
      You can specify when to display the login screen by selecting either “when you start using the machine” or “after a function button is pressed.” If “after a function button is pressed” is selected, you can specify the functions that require user login. Functions that are not specified are available to unregistered users.
      1
      2
      Click [Settings/Registration] on the portal page.Remote UI Screen
      3
      4
      Click [Control Panel Settings]  [Edit...].
      5
      Configure the settings as necessary.
      [Display Login Screen]
      Select when the login screen is displayed. If you want to select whether or not to display a login screen for each function, select [Display login screen when functions requiring authentication are selected].
      [Select Function That Will Require Authentication]
      If [Display login screen when functions requiring authentication are selected] is selected in , select the check box for the functions that display a login screen.
      [Select Background Image]
      You can specify a background image for the login screen.
      6
      Click [Update].
