      0WR6-07R
      Sending/Saving Separately Scanned Documents Together (Job Build)
      Even if you have too many documents to be placed in the feeder at the same time, you can scan the documents separately and send/save them as a batch of documents. Documents scanned with both the feeder and the platen glass can also be sent/saved at the same time.
      1
      Place the first document. Placing Documents
      2
      Press <Scan and Send> on the Main Menu. <Main Menu> Screen
      3
      Specify the destination on the Scan Basic Features screen. Scan Basic Features Screen
      4
      Specify the scan settings as necessary. Basic Operations for Scanning Documents
      5
      Press <Options> <Job Build>  <Close>.
      6
      Press  to scan the document.
      When scanning is complete, the screen appears prompting you to scan the next document.
      7
      Place the next document and press  .
      Repeat this step until you finish scanning all of the documents.
      To change the scan settings, press <Change Settings>.
      8
      Press <Start Sending>.
      All scanned documents are combined into one and sent/saved to the specified destination.
