      0WR6-05Y
      Sending Separately Scanned Documents Together (Job Build)
      Even if you have too many documents to be placed in the feeder at the same time, you can scan the documents separately and send them as a batch of documents. Documents scanned with both the feeder and the platen glass can also be sent at the same time.
      1
      Place the first document. Placing Documents
      2
      Press <Fax> on the Main Menu. <Main Menu> Screen
      3
      Specify the destination on the Fax Basic Features screen. Fax Basic Features Screen
      4
      Specify the scan settings as necessary. Basic Operations for Sending Faxes
      5
      Press <Options>  <Job Build>  <Close>.
      6
      Press  to scan the document.
      When scanning is complete, the screen appears prompting you to scan the next document.
      7
      Place the next document and press  .
      Repeat this step until you finish scanning all of the documents.
      To change the scan settings, press <Change Settings>.
      8
      Press <Start Sending>.
      All scanned documents are combined into one and sent to the specified destination.
