      0WR6-05X
      Sending Different Size Documents Together (Different Size Originals)
      You can place different size documents in the feeder and scan them at the same time.
      The combination of document sizes that you can scan is limited. Scanning with an improper combination may cause damage to the documents or paper jams. Specifications
      Do not place the documents together that are of different weights or paper types. Doing so may cause damage to the documents or paper jams.
      1
      Place the document in the feeder Placing Documents
      To place the documents with the same width, align the top and bottom edges of the documents with the edges of the feeder as shown in the figure below. To place the documents with different widths, align the top edges of all of the documents with the back edge of the feeder.
      For documents with the same widths
      For documents with different widths
      2
      Press <Fax> on the Main Menu. <Main Menu> Screen
      3
      Specify the destination on the Fax Basic Features screen. Fax Basic Features Screen
      4
      Specify the scan settings as necessary. Basic Operations for Sending Faxes
      5
      Press <Options>  <Different Size Originals>.
      6
      Select <Same Width> or <Different Width> and press <OK>.
      Select <Same Width> if you are placing the documents with the same width, or <Different Width> if you are placing the documents with different widths.
      7
      Press <Close>.
      8
      Press .
      Documents are scanned and sending starts.
      When the documents with different widths are scanned together, the images of the smaller size documents may be slanted because the documents cannot be fixed with the document guides.
