      0WR6-03U
      Copying Different Size Documents Together (Different Size Originals)
      You can place different size documents in the feeder and scan them at one time.
      You are limited to certain combinations of document sizes for scanning. Scanning with an improper combination may cause damage to the documents or paper jams. Specifications
      Do not place the documents together that are of different weights or paper types, as this may cause damage to the documents or paper jams.
      1
      Place the document in the feeder. Placing Documents
      To place the documents with the same width, align the top and bottom edges of the documents with the edges of the feeder as shown in the figure below. To place the documents with different widths, align the top edges of all of the documents with the back edge of the feeder.
      For documents with the same widths
      For documents with different widths
      2
      Press <Copy> on the Main Menu. <Main Menu> Screen
      3
      Press <Options> on the Copy Basic Features screen. Copy Basic Features Screen
      4
      Press <Different Size Originals>.
      5
      Select <Same Width> or <Different Width> and press <OK>.
      Select <Same Width> if you are placing the documents with the same width, or <Different Width> if you are placing the documents with different widths.
      6
      Press <Close>.
      7
      Press .
      Copying starts.
      When the documents with different widths are scanned together, the images of the smaller size documents may be slanted because the documents cannot be fixed with the document guides.
      If <Different Size Originals> is set for copying, each document is output with the optimal size of paper. If you want to copy all documents with the same size of paper or copy 1-sided documents of different sizes to both sides, specify the paper with <Select Paper>. If you do not specify <Select Paper>, the output paper cannot be stapled properly.
