      » Appendix » MEAP
      0WR6-0U3
      MEAP
      MEAP (Multifunctional Embedded Application Platform) is a framework for enhancing and optimizing various functions installed on the machine such as "Communication," "Authentication" and "Output." For instance, user management using IC cards and collaboration with software which streamlines file processing becomes possible through MEAP. To enhance functions as stated before, you are required to install a dedicated application called a "MEAP application" on the machine. You can install MEAP applications and check their usage status by displaying the SMS (Service Management Service) from the Remote UI. In order to install a MEAP application, you are required to log in as an administrator (Logging into the Machine).
      Installing MEAP Applications
      You can install MEAP applications and configure the necessary settings to use the MEAP applications.
      Managing MEAP Applications
      This section describes how to check the MEAP applications you installed, how to unistall the applications, and how to manage the licenses.
