      0WR6-0KY
      Checking the Remaining Amount of Consumables
      When you press , the <Status Monitor/Cancel> screen appears, allowing you to check the toner level and the remaining amount of staples.
      TIPS
      You can check the remaining amount of consumables from the Remote UI.
      Checking Toner Level
      It is recommended that you check the toner level before printing a large job to determine whether or not to prepare a new toner cartridge.
        <Consumables/Others>  Check <Remaining Toner>
      Checking the Remaining Amount of Staples
      It is recommended that you check the remaining amount of staples before making a large number of booklets to determine whether or not to prepare a new staple cartridge.
        <Consumables/Others>  Check <Remaining Staples> or <Saddle Staples>
      Messages for remaining staples
      When <OK> is displayed, enough staples remain. You do not need to replace them with a new staple cartridge or staple case.
      When <Low> is displayed, the remaining amount of staples is small. Prepare a new staple cartridge or a new case so you can replace them at any time.
      When <Empty> is displayed, no staples remain. Replace with a new staple cartridge or a new staple case.
