      0WR7-0W1
      <Set Destination>
      You can specify the settings for registering and changing destinations.
      Item
      Description
      <Address Lists>
      You can print a list of destinations registered in the Address Book or one-touch buttons.
      IMPORTANT:
      Even if you set <Set Destination>  <Manage Address Book Access Numbers> <On>, all destinations including those stored with access numbers are printed.
      Setting Value
      <Address List 1> to <Address List 10>, <One-Touch>, <Address List for Admin.>, <Print List>
      NOTE:
      Reports and lists can be printed on 11" x 17", LGL, or LTR paper. However, they may not be printable depending on the paper type.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: No
      <Register Destinations>
      You can register destinations such as fax and e-mail in the Address Book of the machine. Registering Destinations in the Address Book
      IMPORTANT:
      To send faxes using ECM, select <Fax Settings>  <ECM TX> <On> as well as set <ECM TX> to <On>.
      Setting Value
      <Register New Destination>: <E-Mail> (→), <Fax> (→), <I-Fax> (→), <File> (→), <Group> (→), <Register from LDAP Server> (→)
      <E-Mail>
      <Name>: Enter a name.
      <Personal Address List>, <Address List 1> to <Address List 10>, <Address List for Admin.>
      <E-Mail Address>: Enter an e-mail address.
      <Divide Data>: <On>, <Off>
      <Fax>
      <Set Details> (→)
      <To URI Address> (→)
      <I-Fax>
      <Mode>: <Simple>, <Full>
      <I-Fax Address>: Enter an address.
      <Send via Server>: <On>, <Off>
      <Standard Field 1>, <Standard Field 2>: If you do not use an Internet fax service, these settings are not necessary. For details, contact your service provider.
      <Destination Conditions> (→)
      <File>
      <Protocol>: <Windows (SMB)>, <FTP>, <WebDAV>
      <Host Name>: Enter a host name.
      <Folder Path>: Enter a folder path.
      <User Name>: Enter a user name.
      <Password>: Enter a password.
      <Confirm Before Sending>: Enabled, Disabled
      <Search Host> (→)
      <Browse> (→)
      <Check Connection>
      <Group>
      <Name>: Enter a group name.
      <Add from Address Book>: Select a destination.
      <Store in Mail Box>: Select a box (00 to 99).
      <Delete>
      <Register E-Mail Address as I-Fax>
      <All (Max 256)>
      <Search by Conditions> (→)
      <Search by Name>
      <Set Details>
      <Subaddress>: Enter a subaddress.
      <Sending Speed>: <33600 bps>, <14400 bps>, <9600 bps>, <4800 bps>
      <Select Line>: <Auto>, <Line 1>, <Line 2>, <Line 3>, <Line 4>
      <ECM TX>: <On>, <Off>
      <Long Distance>:<Domestic>, <Long Distance (1)>, <Long Distance (2)>, <Long Distance (3)>
      <Communic. Mode>: <G3>, <IP Fax (Intranet)>, <IP Fax (VoIP Gateway)>
      <To URI Address>
      <Name>, <URI Address>, <Set Details> (→), <To Telephone Number>
      <Set Details>
      <Communic. Mode>: <IP Fax (Intranet)>
      <Paper Size>: <A4/LTR>, <B4>, <A3/11x17>
      <Compression Method>: <MH>, <MR>, <MMR>
      <Resolution>: <200x100 dpi>, <200x200 dpi>, <200x400 dpi>, <300x300 dpi>, <400x400 dpi>, <600x600 dpi>
      <Server to Search:>: Select an LDAP server for searching.
      Search categories: <Name>, <E-Mail>, <Fax>, <Organization>, <Organization Unit>
      Search conditions: <Contains>, <Does Not Contain>, <Equals>, <Differs from>, <Begins with>, <Ends with>
      Search characters: Press <Set> and enter search characters for the search condition.
      <Add Search Condition>: Search destinations with multiple conditions.
      <Search Host>
      <Workgroup Name>: Enter a workgroup name.
      <Browse>: Browse a network to find a destination server.
      NOTE:
      If you specify the destination for which you activate <Confirm Before Sending> as the forwarding destination, the screen to enter the password does not appear. The registered password is used and forwarding is performed.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Device Information Distribution Available: Yes
      <Rename Address List>
      You can rename each address list.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Register One-Touch>
      You can register destinations such as fax and e-mail in the one-touch buttons of the machine. Registering a Destination in a One-Touch Button
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Change Default Display of Address Book>
      You can specify the type of the Address Book that you want to display when you press <Address Book> on the Fax Basic Features screen or the Scan Basic Features screen.
      Setting Value
      <Local>, <LDAP Server>, <Remote>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Can be set in the Remote UI: No
      <Address Book PIN>
      You can set a password for the Address Book.
      DeviceAdmin: No
      NetworkAdmin: No
      You can select whether to allow users to set an access number for a destination when registering in the Address Book.
      Setting Value
      <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: No
      <Include Password When Exporting Address Book>
      You can select whether to include the passwords registered for destinations when exporting the Address Book using the Remote UI.
      Setting Value
      <On>, <Off>
      NOTE:
      If this setting is set to <Off>, it is necessary to register passwords for the destinations again in the machine the Address Lists are imported to.
      You can set whether to export the following passwords:
      The password for subaddress transmission set in fax destinations
      The authentication password set for file server destinations (including the Advanced Box that is opened externally)
      DeviceAdmin: No
      NetworkAdmin: No
      <Register LDAP Server>
      You can specify the settings of an LDAP server, such as a server name and server address, you are using when searching for destinations or registering them. Registering the LDAP Server
      Setting Value
      <Register> (→), <Details/Edit> (→), <Delete>, <Print List>
      <Register>, <Details/Edit>
      <Server Name>
      <Server Address>
      <Position to Start Search>
      <Use TLS>: <On>, <Off>
      <Port Number>: 1 to 389* to 65535
      *636 when <On> is selected for <Use TLS>
      <Max Addresses to Search>: 1 to 100 to 2000
      <Search Timeout>: 30 to 60 to 300 sec.
      <Next> (→)
      <Next>
      <Authentication Information>: <Do Not Use>, <Use>, <Use (Security Auth.)>
      When <Do Not Use> is selected
      <LDAP Server Version and Character Code>: <ver.3 (UTF-8)>, <ver.2 (UTF-8)>, <ver.2 (SJIS)>, <ver.2 (EUC)>, <ver.2 (JIS)>, <ver.2 (ISO8859)>
      When <Use> is selected
      <Display Authentication Screen When Searching>: <On>, <Off>
      When <Use (Security Auth.)> is selected
      <Domain Name>: Enter a domain name.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Auto Search When Using LDAP Server>
      You can select whether to automatically start searching for destinations when accessing an LDAP server from the machine. If you set this setting to <On>, all users with fax numbers or e-mail addresses registered are displayed as the search results when accessing the server.
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Change Default LDAP Search Conditions>
      You can register frequently used search conditions as the default settings for searching an LDAP server.
      Setting Value
      <Register>, <Initialize>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Register/Edit LDAP Search Attribute>
      You can register the search attributes used when searching an LDAP server.
      Setting Value
      <Register/Edit> (→), <Delete>
      <Register/Edit>: <Display Name>, <Attribute Name>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Settings for Search by Name When Using LDAP Server>
      You can specify the attribute used when searching an LDAP server for destinations by name.
      Setting Value
      <Name Type for Search Attribute>: <cn>, <commonname>, <fullName>, <displayName>, <sn>, <givenName>, <Custom>
      <Filter>: <Contains>, <Does Not Contain>, <Equals>, <Differs from>, <Begins with>, <Ends with>
      DeviceAdmin: Yes
      NetworkAdmin: No
      You can specify the settings to access the Address Book (Remote Address Book) of another imageRUNNER ADVANCE series machine on a network from this machine.
      You can specify the settings to open the Address Book of this machine to another imageRUNNER ADVANCE series machine on a network.
      <Use URI When Registering New Fax Destination>
      You can select whether to specify a URI address to register the destination. IP FAX Expansion Kit User's Guide
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Use Personal Address List>
      You can select whether to use a personal Address Book of a user who logs in to the machine with personal authentication management.
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: No
      <Use User Group Address List>
      You can select whether to use a User Group Address List.
      Setting Value
      <On>, <On (Browse Only)>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: No
