Item
Description
<Auto Adjust Gradation>
You can perform the auto adjustment to correct the gradation if the printing result is significantly different from the original document when you copy an image. Adjusting Gradation
IMPORTANT:
Auto Adjust Gradation appears when the imagePASS is installed.
Make sure that you place the test pages properly. Accurate recalibrations of the gradation and density settings of the machine cannot be made if the test pages are not scanned correctly.
Only plain paper can be used for printing test pages with this machine. You cannot select a paper source loaded with a type of paper other than plain.
NOTE:
Test pages are not counted as part of the copy or print total page counts.
If paper appropriate for the test page is not loaded in any paper source, a message asking you to load the appropriate paper appears. Load the appropriate paper in a paper source.
DeviceAdmin: Yes
NetworkAdmin: Yes Can be set in Remorte UI: No Device Information Distribution Available: No |
<Correct Density>
You can recalibrate the density adjustment scale if differences between the image on the original document and the print occur. Adjusting Print Density
Setting Value
<Black & White Scan for Copy/Scan and Store (Mail Box)>: 1 to 5 to 9
<Black & White Scan for Send/Scan and Store (Other Than Mail Box)>: 1 to 5 to 9 <Color Scan for Send/Scan and Store>: 1 to 5 to 9 DeviceAdmin: Yes
<Fine Adjust Zoom>
When copying, a slight difference in size may occur between the size of the original image, and the size of the copied image. In this case, you can perform a fine adjustment to compensate for this difference. Adjusting Image Size
Setting Value
<X>: -1.0% to 0% to +1.0%, in 0.1% increments
<Y>: -1.0% to 0% to +1.0%, in 0.1% increments DeviceAdmin: Yes
