      0WR7-0JL
      <IC Card Authentication>
      Specify the settings for the login screen displayed when using IC card authentication. Configuring the User Login Methods and Authentication Devices
      Item
      Description
      <Display Button on Settings Menu>
      Select whether to add buttons for corresponding operations to the menu that is displayed by using  on the top right corner of the login screen.
      Setting Value
      <Register IC Card>: <On>, <Off>
      <Delete IC Card>: <On>, <Off>
      <Change IC Card PIN>: <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: No
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: Yes
